Running STAAD files sequentially overnight
Due to workstation limitations, I need to run (analyse) two seperate staad model files overnight at work, from my windows machine.
I recall (from way-back-when) that this can be achieved by creating a user executable file (or was it a *.cmd or *.bat file, I can't recall) using just Notepad containing a couple of lines of simple DOS commands and pointing to the filepaths. Can anyone help? Tried googling this but didn't get very far.
Cheers
  • Please refer to the following link for the answer. Please let me know if this does not answer your query.
    communities.bentley.com/.../254111.aspx
    Sudip Narayan Choudhury
    Answer Verified By: Matt Goswell
  • Thanks for your reply
    I've looked into this and you can also run direct from the command line as follows:
    "filepath where SProStaad.exe is saved in quotation marks" /s staadfilepath.std
    for example, open Notepad and save these lines as a *.bat file (saving in Notepad under "all files" as save type). The /s is a switch to run files sequentially.
    "C:\Program Files\SProV8i\STAAD\SProStaad\SProStaad.exe" /s C:\MyStaadFiles\Model_1.std
    "C:\Program Files\SProV8i\STAAD\SProStaad\SProStaad.exe" /s C:\MyStaadFiles\Model_2.std
    "C:\Program Files\SProV8i\STAAD\SProStaad\SProStaad.exe" /s C:\MyStaadFiles\Model_3.std
    "C:\Program Files\SProV8i\STAAD\SProStaad\SProStaad.exe" /s C:\MyStaadFiles\Model_4.std
    etc etc.........
    Double click your batch file and it will run the staad files sequentially. This is a vanilla way of running multiple files without having to open an application with VB.
    Have a good day
