Is there a way to get information from a model created in Ram Elements to Ram Foundation?
Thanks!
RAM Foundation is a module in RAM Structural System. There is not a direct link that will take information from RAM Elements and import it into RAM Structural System.
Data can be exchanged between RAM Elements and RAM Structural System through the ISM product, however. See the following web page for details:
http://communities.bentley.com/products/structural/w/structural__wiki/integrated-structural-modeling-home.aspx
Note that there are limitations with the data that is imported/exported for each program. The following web page has more details on these limitations:
http://communities.bentley.com/products/structural/w/structural__wiki/capabilities-and-limitations.aspx
Answer Verified By: RFreund
There is foundation design (spread footings and combined footings) right in side of Ram Elements, don't forget.
@kjgullerud
So you can go from Elements to RAM SS to Ram Foundation w/ ISM. Thanks for the info.
@Seth
I actually overlooked that., that should work. Thank you.
