Running a version of RAM Concept that uses a hardware lock
This post is being submitted on behalf of a user with the following question:
When I re installed the RAM Concept 2 with Super Pro (single License) it is giving me following error message. Please note that I have the latest V14 but I do need to work on some old projects which I dont want to convert so I need to use the RAM Concept 2.
"Copy protection error (No RAM Concept license available) A setting dialog box will open then the program will exit."
After this a dialague apears where I am selecting Super Pro and on clicking on OK I am getting following error message
Runtime Error! R6025-Pure virtual function call
  • Hardware locks such as your Sentinel SuperPro require a driver to function. However, the driver included with RAM Concept 2.x is not compatible with Windows Vista and later, and even with Windows XP, the latest driver can help. Please download the latest Sentinel Driver from the hardware lock vendor's website at:
    www.safenet-inc.com/.../Sentinel_Drivers
    Once installed, attempt to access RAM Concept 2.x again.
    For anyone who has an older version of RAM Concept using a hardware lock that is installed alongside newer versions using SELECTserver, you will need to swap a licensing communication library when switching between the two versions. Please refer to the following file post on Be Communities for more information.
    Answer Verified By: Jeremy Hoesly
