Hai Friends
I'm looking for a help from u all for the API 5L sections or equivalent which is available in STAAD section database or not. If I create my own database then how I need to configure it in Section DBmanager and as well how to get the user database in STAAD Section property selection tab/ table.
Thanks in advance for ur support
I have made a small video on how to add mdb files to the Section DB. You may download it from
ftp://ftp.bentley.com/pub/outgoing/mdb%20to%20SectionDB.7z
This is just a sample video with arbitrary sections used.
Answer Verified By: Bagmass
Hai shany
thanks for ur reply & video. Its clear to me now. But I have one questions to u. Can we make a separate database for example in European we have HE Shape section. If need to add new properties means Either I need to add sections to the Exisiting or I need to delete completely all HE shape and inside the it i need to update. I need a separate section database inside European without removing anything or adding to HE shape. Is it possible to Have two HE shape table or I can give some new name lets say Plate Girder (PG SHAPE) how could i access in STAAD Section property selection tab/ table to assign the property.
