Dear friends
I need your help to solve a error when i try to open Staad pro model in STAAD offshore. I'm not able to load my model because user defined section database property developed in STAADPRO is not recognized in STAAD Offshore. How i need to solve this problem and how to use user table properties in STAAD Offshore. I added few new property using STAAD DB manager which is not regonised by STAAD offshore now.
Thanks & regards
BAGMASS
The answer to your query is now posted at
communities.bentley.com/.../8332.aspx
Answer Verified By: Bagmass
Hai Sye
Thanks for your kind support. my earlier problem is solved now i came up with new problem. could u please help us. we assigned few members in our model STANDARD Circular hollow sections (CHS) european Its shows section Invalid. for ex. we assigned 406.4x10 CHS we got warning when opening the model. please find attached the snap. we assigned first few user defined section developed throug DB manager it shows this warning then we assigned the standard sections available in European section CHS. we got the same warning. It reads all Open sections (I-section both standard and user defined but not the circular or Pipe sections. It reads Tube sections without any issue. we are looking for your reply. thanks advance .
System configuration FYI
we are using STAAD ProV8i Seclect series 4 and Staad OffshoreV8i_ 3.0.1.2. OS windows 7 Enterprise Service pack 1 , 64bit , 8GB Ram.
Bagmass
