Dear Sir,
I will explain how I do to generate the loads and analyze my structure and explain my problem/
Hereafter the warning message:
WARNING: IN UNIFORM MEMBER LOAD. ITEM "f3" NOT PROVIDED FOR MEMBER 4566 CASE 17 "f3" ASSUMED TO BE MEMBER LENGTH = 1.28
Moreover when I compare the global resultant generate with Staad Pro and Staad Offshore I do not get the same results? WHEREAS I have done a copy/paste. See example hereafter (results are closed but different...).
Waiting for your help.
RESULT WITH STAAD OFFSHORE:
BASE SHEARS AND MOMENTS GLOBAL SYSTEM-Maxima and Minima FORCE WAVE XYZ BASE SHEARS XYZ BASE MOMENTS POSN FX FY FZ MX MY MZ (kN) (kN) (kN) (kNm) (kNm) (kNm) FX+ -15 121. -16. 0. 5. 48. -165.
RESULT WITH STAAD pro
***TOTAL APPLIED LOAD ( NEWT METE ) SUMMATION FORCE-X = 142538.48 SUMMATION FORCE-Y = -16637.79 SUMMATION FORCE-Z = -82.47 SUMMATION OF MOMENTS AROUND THE ORIGIN- MX= 5756.32 MY= 51260.14 MZ= -192719.19
