CLAUSE IN STAAD PRO
I have a number of beam in my model and when i run a unity check some fail by different "clauses" Below are all the list clauses that i am coming up with.
clause h1/2
clause h3
clause g
clause e2
Does anyone know where i can find a definition of these "clauses".
Thank you
  • The clause reported in STAAD.Pro is a reference to the exact chapter or equation on the design code which is governing for that particular member. For example, if you are using AISC UNIFIED design code, then clause h1/2 means that critical condition for this member is described in the code Chapter H - DESIGN OF MEMBERS FOR COMBINED FORCES AND TORSION. Other mentioned clauses can also be found in the same design code.
    Answer Verified By: eric hollmann
Reply
