Base plate design - using support reaction or beam end force
Hi, everyone.
I encountered a doubt while I am designing Base plate of Steel column.
The question is which output should I use for my base plate of Steel column.
Which one is normally recommended when designing Piperacks or Equipment supporting steel structures ?
- Situation1) Using Beam end force of the steel column with modeling of concrete pedestal or
- Situation2) Using Support reaction of the steel column without modeling of concrete pedestal.
Situation 1)
- Structural steel frame and concrete pedestals are modeled.
- Support conditions are given to the bottom node of concrete pedestal
- Bottom node of steel column has beam end release condition according to the structural configuration and anchor bolt arrangement
- Then, I get beam end forces of the steel columns and can use them for designing of base plates.
- And, additionally, support reactions are used for designing concrete foundations
Situation 1)
- Only Structural steel frame are modeled. (concrete pedestals are not.)
- Support conditions are given to the bottom node of Steel columns according to the structural configuration and anchor bolt arrangement
- Then, I get support reaction at the bottom side of the steel columns and can use them for designing of base plates.
- And, in this time, duplicated and modified model with concrete pedestal is required to get output for concrete pedestal and foundation design.
I am waiting for your opinion.
Thank you!
YJ Kim
