In the Staad pro app folder, there is a folder called "Examp", e.g. C:\SProV8i SS5\STAAD\Examp\,
which contains lots of std files in this folders, but I can't find descriptive documents for these examples,
Does the documents exist? if the answer is yes, then where it is located?
if not, does Bentely plan to make a document for these examples?
Other commercial softwares, like Sap2000, ETabs, Midas Gen, Midas Civil, Ram, Risa, Autodesk Robot Structural Analysis, all have detailed documents for their examples.
Along with the example problem, you can find verification problems in the folder.
The verification manual can be downloaded from the following link.
docs.bentley.com/search.php
Thank you guys for the quick reply.
I notice those Example Problems in the Help manual and the verification manual in PDF format,
but I still couldn't find the corresponding document for the example files:
such as
C:\SProV8i SS5\STAAD\Examp\Advanced Cable Analysis\
and
C:\SProV8i SS5\STAAD\Examp\Geometric Nonlinear Analysis\
Please refer to the following section of Help Section. You can go to Help> Contents.
Only some of the examples that are in the folder C:\SProV8i SS5\STAAD\Examp\ are explained in the Application Examples manual.
If there are any specific examples for which you want the explanation, please let us know and we will post the explanation on this site.
Answer Verified By: netsonic
I want to see the explanations of examples under:
Thank you guys for the replies.
In the following items you can find one example, related information posted in Be Communities Forums, Blogs, and More:
1. v2007 Verification Manual
docs.bentley.com/product.php
Non-Linear Static Analysis
Verification Problem STAT-NONLIN-1
OBJECTIVE: To verify P-Delta analysis for a Ten story plane frame.
REFERENCE: Naeim, F., “The Seismic Design Handbook,” Van
Nostrand Reinhold, 1989.
PROBLEM: Find the lateral displacement of the 10th story after two
iterations of P-Delta analysis
2. Be Communities -- Forums, Blogs, and More
communities.bentley.com/.../default.aspx
3. Advanced Analysis Engine in STAAD.Pro V8i
Madhan Elumalai, Bentley Systems
connected.bentley.com/viewSeminars.aspx
Learn about the robust features in STAAD.Pro's Advanced Analysis Module. Improve your productivity today with our faster solver, using non-linear analysis when simple elastic analysis or p-delta is not enough. There are even additional meshing options. The eSeminar will cover the following seven key features: Faster solver (over 1,000 times faster!), advanced mesh generation, eometric non-linear analysis, pushover analysis of steel frames using FEMA-356 code, floor spectrum analysis, advanced buckling analysis, and steady state analysis.
4. Bridge Design with STAAD - ESEM_035
Watch this demonstration and learn about the many uses of STAAD. Learn how to use the moving load option in STAAD.Pro and watch an introduction to STAAD.beava. Learn about: How to use the moving load option in STAAD.Pro to model the vehicle loads. Simplified linear analysis of cable stayed bridges using member tension and member cable command. Non-linear cable analysis to model suspension bridges using STAAD.Pro. Watch an introduction to STAAD.beava for Influence line and influence surface generation and vehicle load calculation.
5. Seminars filtered by: cable
connected.bentley.com/BrowseLive.aspx
6. Also you can try a search by google "staad cable analysis", "staad geometric nonlinear analysis"
@vtello28,
The video in introductory, it will be very useful if Bentley provides the model in the video and descriptive documents for the model, so users know how to deal with engineering problems,
