RAM Connection v8.0.1.34 - Internal Design Error in Connection
I created a custom base plate connection and tried to apply it to a column base node and I got the following error:
"[Error] No connections could be assigned to joint "Node(340) - Column(177)"
[Information] Internal design error in the connection. Please contact technical support
[Information] No connection could be assigned"
