I noticed in my model that it says several connections are OK, but then the unit ratio is up to 50% overstressed! Is this an adjustable setting or an error? The connections happen to be direct welded connections of WF beams to HSS columns if that helps.
Please share your model:
Instructions for uploading files can be found here: http://communities.bentley.com/help/w/be_communities_help/7079.be-communities-secure-file-upload.aspx
I uploaded the following files:
Lateral-North - Copy.rss
Make sure that "For the Controlling Combination" is checked when clicking View - Status. If it is not, then the results will only be displayed for the active load condition.
Answer Verified By: Robert Vida
Yep that was it, I guess I'm still getting used to the program. I knew there was a "for the controlling combination" button for stress ratios but I didn't realize there was a separate one for status.
THANKS!
