i was modelling a approach platform using STAAD Pro V8i.
i am facing the following errors
***WARNING - INSTABILITY AT JOINT 7 DIRECTION = FX
***WARNING - INSTABILITY AT JOINT 7 DIRECTION = FZ
i tried to apply all the possible solutions i got from the discussion but nothing is working
can someone plz analyze the model and suggest me some solution
i am attaching the related file
Check your units in the model. I think that you wanted to use millimeters, but used meters. Change the units and instabilities should go away.
Modestas
Answer Verified By: Maveric049
Please follow the link below which explains the reasons for the instability issues in Staad.pro.
communities.bentley.com/.../2046.aspx
Mr Biswa is it possible to change the Units from Meters to Millimeters after creation of the total model
if so can u plz guide me for doing the same
Open the STAAD Input file by going to Edit -> Edit Input Command File. After the line END JOB INFORMATION change line UNIT METER KN to UNIT MMS KN.
Also, add line UNIT METER KN before the line DEFINE MATERIAL START in the input file.
thank sir
Your suggestion has helped me solve the problem
