Ram Frame Steel Codes
What's the difference between the steel design codes for Ram Frame?  I'm noticing that my model will run without failures and with significantly lower unity check numbers under AISC-ASD than any other code I select.  Any idea why this would be happening?  I always thought LRFD would give more precise numbers and that ASD was more conservative in the design process.
