STAAD ERROR MESSAGE
Dear Sir/Sirs,
Am new to STAAD Pro. I have designed an intake using plate model. Assigned loads. When i try to analyse following error appears.
PRIMARY LOAD CASE CAN ONLY BE ADDED IF SET NL COMMAND IS USED.
How can i rectify. Please help.
Reg
Varad
Intake 14-11-13 (Dikchu HEP) with concrete backfill.std
Parents Reply
  • When a model contains more than 25 load cases, with some being solved using one set of conditions and others being solved with another set of conditions, a command known as "SET NL nn" is required where nn is a number which is at least equal to the number of load cases.
    In this case, this condition is achieved by the CHANGE command that you have used after every analysis. As it turns out from the STAAD  model  you have attached, the total number of load cases is beyond the default number of load cases the space has been reserved for. Hence, I have used the SET NL command. This command instructs the program to set aside additional memory space for information to be added later.
    Open the Staad Editor File, and before the JOINT COORDINATE command line, add the command SET NL 100 (for this model I have added 100)
    Answer Verified By: Varadha Rajan
