Dear Sir/Sirs,
Am new to STAAD Pro. I have designed an intake using plate model. Assigned loads. When i try to analyse following error appears.
PRIMARY LOAD CASE CAN ONLY BE ADDED IF SET NL COMMAND IS USED.
How can i rectify. Please help.
Reg
Varad
Dear sir,
Now it works. Thank u a lot sir. But it showed about 9 warnings that iteration limits does not converge and suggested to use set iterlim command. I have under stood and cleared that too in the same way. Thanks again
Happy to help.
