Hello I'm just a beginner in staad pro. I'm trying to design a 6-storey building. After analyzing the structure i used commands option to perform concrete design. It gave me reinforcing details for column and beam. But not for slab. I added plates for slabs and perform quadrilateral surface meshing.(I read that in a tutorial I don't even know what surface meshing is) My questions are:
1) What should I do to design slab? 2) Can i perform calculation of lift and stairs in staad pro? if so then how? Please take a look at my file and point out any error.
Thanks and appreciation in advance for help.
Can anyone please explain how can I design columns and beams by taking results from a solid model i have generated in staad.
hello sir suro i have a question regarding the sq.in/ft. ratio, can you please elaborate more on this, for example if on this design the reinforcing steel that i going to be use is #3 bars what would the spacing be? i dont understand the output... the part that has (top : 0.130) <--------is this the ratio? and what is it for? thanks in advance
Hi sir , i have a qstion
How to design beam and slab simultaneously in staad
If i give floor load plate wont be considered
If i give plate load that won be transfered to beam (plate not meshed to get descent ast ) is there a way to get proper design of beam and slab in staad
I think its better to design Column and beam once, then slap
Hi, i am facing a issue that slab reinforcement shows none why?
