Ram Footing Module - Detailing
How do I eliminate Zones in the detailing tab?
I'd like the same reinforcement throughout the length
  • I assume we are talking about the transverse reinforcement for combined footings in Ram Elements here. According to the help:
    • Zone: reinforcement in short direction of the footing is distributed by zones. Zones under columns usually require more reinforcement area because of the concentration of stresses; the remaining reinforcement is distributed uniformly in the zones without columns. Spread footings with centered columns initially have three zones defined and combined footings have five zones defined by zone1, zone2, zone3, zone4, zone5. The quantity of zones is closely related with the position of the column and the zone width is calculated according with the design code.
    The zones are generated automatically and cannot be purged or adjusted, I'm afraid.
    Answer Verified By: RFreund
  • Is there anything in the works to allow the use of a single reinforcement zone for the transverse direction
