Say I have modeled the slab, set the design strips even ran the analysis. Now say I want to change the slab thickness. How do I do this?
Thanks.
In the Mesh Input layer select the slab polygon(s) of interest, right click, select properties. You can change any of the properties including thickness. After any changes are made in the Mesh Input layer, don't forget to re-mesh.
Answer Verified By: RFreund
Ahhh, not sure how I missed that. I looked there several times... Haste makes waste I guess.
Thank you
