Ram Elements - Plates and Tanks
I have a couple questions on plates in RAM Elements.
1. Can you model a plate with different boundary conditions. i.e. Fixed sides, pinned bottom and free top or some combination of these?
2. Sorta relating to the above - Is there a good way to model an underground tank in elements. Meaning I would like to apply an area load for soil and surcharge pressure. This load would be uniformly varying top to bottom. Maybe you could use a series of line loads on very flexible members with very low MOE? Again I'm not sure how you set up the support constraints. This would make for an interesting article in using your software possibly or any FEA for that matter.
Thanks again!
