Sir,
I have modeled a achitectural projet in which the column size is 230x1150 mm. Since the column size exceeds the codal provisions modeled the column as a shear wall. The analysis ran successfully and got no error. But while designing the shear wall I got the following message as:
"FAILED. NO REBAR IS AVAIABLE FOR VERTICAL REINFORCEMENT AGAINST OUT-OF PLANE BENDING CHECK"
Can the technical dept help me to solve the above? Can I increase the size or other means please.
Thanks in advance.
T.RangaRajan.
Dear Sir,
If I remember correctly, this problem occurs because STAAD includes out of plane bending of shear wall to account for displacement equilibrium - you will probably need to go for thicker wall...
Yours sincerely
Arunkumar
Dear Er.Arunkumar,
If the thickness is restricted then is there any solution to avoid this message?
Thanks for your reply.
With warm regards,
T.Rangarajan.
As far as I know, there is no other solution. You can try contacting Bentley support team for more info.
S Arunkumar
