<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>STAAD.pro Global Statics Equilibrium Problem</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/96809/staad-pro-global-statics-equilibrium-problem</link><description>Hello,
 I am having some problems with a model I am trying to run for deflection purposes. The structure is a steel plate girder bridge with a composite concrete deck. I originally had the full structure modeled using beam elements for the girders and</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: STAAD.pro Global Statics Equilibrium Problem</title><link>https://communities.bentley.com/thread/283395?ContentTypeID=1</link><pubDate>Sat, 03 May 2014 00:29:16 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:7be43eec-28de-46c8-bcf7-7042453946cd</guid><dc:creator>Sye</dc:creator><description>&lt;p&gt;Please replace the master slave definitions at the end nodes ( ones with supports at the master nodes ) with two manually defined rigid link members. A modified file is attached for your reference.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description><enclosure url="https://communities.bentley.com/cfs-file/__key/telligent-evolution-components-attachments/00-5932-01-00-00-28-33-95/modified.std" length="4225" type="application/octet-stream" /></item></channel></rss>
