help needed with concrete design analysis report
Hello everyone, i just need to know if it's possible to print data about the area of reinforcing steel on the reports that can be made by staad.pro, also if there is a way to show those values the same way it does with bending, shear, deflection, envelope, etc. I mean, when you want to take a picture to include on that report, you have the choice to show those values along with the graphics displayed, for example, max bending, and bending at each end of the beam, i want to do this mostly with reinforced concrete structures, the output file does show most of that info, it even makes a drawing of the beam with the rebars and how many should be used and how to place those reinforcements, but i can't see the same with reports, maybe i'm missing something, or if there's another way to proceed, i would be really grateful for any tips you can give me
Parents Reply Children
