Arch Culvert in STAAD pro
I am modeling RC arch culvert in STAAD PRO and I am interested in obtaining the shear force and bending moment values. This is a buried structure. I input the lateral earth pressure and vertical load due to backfill as trapezoidal load on the member segments. the support conditions are hinged. when I analyzed the structure and checked the shear force diagram under self weight, I could not be convinced with the output. Shear value was the least at the supports and showed sharp change at each of the nodes.  Need Help.
Parents Reply Children
