Cantilever beam below a story level?
Can I model a cantilever beam coming off the face of a column below a story level?  I found where to slope the cantilever, but I want the cantilever to be located 4.83' below the story.  I tried adding a story for these beams and just didn't have a diaphragm for that story.  The columns were all made into fully fixed connections at that level, but it caused some failures in columns that were previously working.  Oddly enough, the columns that are now failing are frame columns on the interior of the building.
Is there some way I can model these cantilevers at the level I want and not have a new story just for the beams?  Or can you explain why the new level is causing problems with columns that previously worked?  The building is 4-story, has moment frames throughout, and the cantilever beams added have minimal loads (840lbs acting 5' away from the face of the column).  I even removed the loads to see what would happen to the model and the same interior columns are failing.  Something about breaking the columns without having a diaphragm at that level is throwing things off.
Thanks!
Lance
