Hi
I have designed a steel building using IS 800-2007 . A few beams have failed . I am not able to identify the reason for this failure pattern. Please help. ( I have attached the staad file )
You need to get you input file correct in the first place. You have used the UNL parameter which is not a valid parameter for IS 800 LSD. For Lateral Torsional Buckling, please use parameters KX (effective length factor for lateral torsional buckling), LX (effective length for lateral torsional buckling)and LAT (Lateral Restraint parameter for compression flange).
Moreover, IS 800 2007 LSD implementation in STAAD does not as yet consider the double profile sections. You have assigned these sections to a lot of members. This is the reason why this has not been designed.
Sudip Narayan Choudhury
CAN I DEFINE LAT PARAMETER FOR RAFTER WHILE MY RAFTER IS CONNECTED WITH PURLIN AND FLANGE BRACE AND DESIGN WITH IS 800-2007
