Wind load on surface meshing
Hi
Can you tell me if this correct?
I generate surface meshing between my members (beams and columns), then I set the area load as a "pressure on full plate". I chose steel as a material for plates with thickness = 0.1mm to get a negligible weight and stiffness.
Is this right?
In which way will loads be distributed? (one way/two ways)
  • You'll find lots of similar posts on this forum. Just search for " composite beam plate ", for example.
    I generally don't like to use plates for the sole purpose of transferring loads, because the plates and the beams will interact compositely and even a thin plate can affect the stiffness, deformation, distribution of stresses, etc.
    STAAD.pro and Ram Elements both offer tools for creating area loads (see 1.16.3 Area Load, One-way, and Floor Loads in STAAD.pro) that are distributed to the framing in either a one-way or two-way fashion.
    Answer Verified By: WKHA
Reply
