Dynamic Response Analysis - Input
In a Dynamic Analysis when defining a seismic load cases and using the command "SPECTRUM" does one use the site specific "Seismic Response Coefficient" Cs based on S1 and Ss accelerations derived from ASCE 7?
For example, if I calculated a Cs = 0.065  (ASCE 7 12.8-2) would the input line be as follows:
SPECTRUM SRSS X 0.065 Y 0 Z 0 ACC SCALE 32.2 DAMP 0.05
Thus, this would be a Seismic Load Case for the X-Direction based on spectral acceleration.  Then a load case for each direction in  x, y and z, using Cs, would be added to the seismic load case.  Is this the correct approach?
Thank you for any input.
