I have designed an alignment for one of my project sites after importing site survey points in open roads. Now i am attaching an autocad file of features at the site.
The issue is that as i attached my cadfile its coordinate system changes.Its is not attached at same location as my designed alignment.
Hi Atif, Does the file have negative co-ordinates? If yes, you will have to set the negative co-ordinates in project settings in MX. The below link will help you set the negative co-ordinates: communities.bentley.com/.../28479.negative-co-ordinates Hope this helps. Do let me know.
Sagar PLAN.dwg
GENIO.TXT
