This has been implemented for InRoads V8i SELECTseries 2 release.
Until then, you can use the Draw Slope Direction Pattern command under the Drafting menu.
HTH
Thomas
That was great news about SS2. Until then I stick to my old method, im using AutoCAD and have developed a swifter solution for BatterTicks with AutoCAD.
Is there any release date for SS2?
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
