MXRoads SELECTseries 10 is now available for download.
As communicated, we began the sunsetting phase of the SELECTserver on January 1, 2021, support will be discontinued for application versions prior to V8i SELECTseries10.
To provide you with the time and flexibility to upgrade to current versions of your Bentley applications, we are delaying full deprecation and instead are implementing SELECTserver fees for those continuing to use non-current application versions, which are licensed by SELECTserver. Upgrade now to minimize additional fees.
Here are some resources to help you migrate to current versions of your applications:
We’re committed to helping you get the most from your investment in Bentley software, and to enhance security and create better workflows for your entire organization.
Please contact successforce@bentley.com if you need assistance.
With the release of MX SS10 (UK) is there also going to be MX SS10 (Australia - AU version) plus MXTools SS10 release as well????
Stewart SmithPrincipal Road Designer - GHD (Melbourne)
Is it possible to install it along SS4 and SS2?
I work on multiple projects and need to maintain compatibility and productivity.
Thank you in advance.
Val.
On the InRoads and GEOPAK side, Ss4 and Ss10 are interchangeable, but when you install Ss10, it removes Ss4. So you can have Ss2 and Ss4 or Ss10. I would expect that MX Ss10 and Ss4 are equally interchangeable.
Stewart sorry the answer here is no regional versions are not being created. However this version can be installed to update the regional AU version so you can retain all the regional settings / files and since the version is the same generation the tools continue to work (assumes SS4 to SS10 is the upgrade path).
Ian
Valeriu, the SS10 and the SS4 version are the same generation and so can't be installed together but you can have SS2 and either SS4 or SS10. It's worth noting though that the only difference between them is the addition of CONNECT licensing at SS10 to help address SelectServer retirement.
