Coffee Corner: OpenRoads - Using Geometry Builder
Title: Coffee Corner: OpenRoads - Using Geometry Builder
Presenter: Scott Urbas, Senior Content Engineer, Bentley Systems, and Chris Collins, Senior Consultant, Bentley Systems
Date and Time: August 11, 2021 at 9:00 AM and 5:00 PM EDT
Register Now! AM
Register Now! PM
Have you ever wondered how to create parcels and alignments by simply entering geometric data in a tabular format?
The Geometry Builder allows you to quickly and easily define geometric data in a tabular format.  In this Coffee Croner, you will learn how to use the OpenRoads Designer Geometry Builder to:
  • create parcels and alignments
  • manage parcels and alignments
  • edit parcels and alignments
Bentley OpenRoads Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters.  Help
