Title: Coffee Corner: OpenRoads Designer - Using and Defining Superelevation Presenter: Scott Urbas, Senior Content Engineer, Bentley Systems IncDate and Times: Wednesday, November 10, 2021 at 9:00 AM EST and 5:00 PM EST
Register Here for the 9:00 AM SessionRegister Here for the 5:00 PM Session
In this OpenRoads Coffee Corner you will learn how to create, edit and review superelevation information using the tools provided in OpenRoads Designer.
You will learn how to create superelevation sections, lanes and transitions and how to apply the superelevation transitions to your corridor. You will also learn how to review and edit superelevation data.
Skills Taught:
Bentley OpenRoads Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
