Title: Coffee Corner: OpenRoads - Setting Up Drawing Sheet Seeds in OpenRoads Designer (AM)Presenters: Bob Rolle, P.E., Application Engineer, Bentley Systems, Inc. and Scott Urbas, Senior Content Engineer, Bentley Systems IncDate and Time: Wednesday December 8th, 2021 at 9:00 AM EST and 5:00 PM EST
Click here to register now for the 9:00 AM Session!
Click here to register for the 5:00 PM Session!
Have you ever wondered how to create drawing sheet seeds in OpenRoads Designer?Setting up drawing sheet seed definition files (.dgnlib’s) allow a user to select a drawing seed to populate all the settings required for creating Named Boundaries (sheets) in plans production. Creating these seed files requires setting very specific properties.
In this session, you will learn how to create drawing sheet seed definitions files and the role they play in sheet creation.
Bentley OpenRoads Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number. Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters. Help
