Coffee Corner: OpenRoads UK - Using the Analysis Tools in OpenRoads Designer
Title: Coffee Corner: OpenRoads UK - Using the Analysis Tools in OpenRoads Designer
PresenterMarc Blancher, Senior Technical Support Engineer, Bentley Systems, Inc.
Date: Thursday, March 31, 2022
Time: 12:00 PM British Summer Time
Register Now!
In this Coffee Corner, you will learn about the many analysis tools of OpenRoads Designer, including:
  • Points
  • Areas
  • Volumes
  • Hydraulic
  • Aquaplaning
  • Sight visibility
Bentley Coffee Corners are open to all Bentley users, free of charge. One learning unit is applied to each participant’s Bentley Transcript for self-reporting. To view prior sessions, watch the Recordings On-Demand.
**The webcast will be streamed through your computer, so there is no dial-in number.  Please make sure your computer speakers (or headset) are turned on and the volume is set to an audible level so you can hear the presenters.  Help
