OpenSite/OpenRoads/OpenRail Designer 2022 Release 1.1
2022 Release 1.1 (10.11.03.02) contains two fixes, as follows:
  • A fix for an exception when you change to DWG mode with the Feature Toolbar open and docked
  • A fix for an exception when opening a design file if you’ve previously opened a Drainage and Utilities Engineering Profile
The Drainage and Utilities issue only occurs when you have opened an Engineering Profile, which is done using the right-click menu on a profile run in the Explorer, as shown in the image below. The result is that the design file is not able to be opened again.
Design files that have been affected by this issue can be repaired by contacting Bentley Technical Support. Please raise a Service Request to start this process.
