Geopak SS3 Civil Cells
We seem to be having an issue when placing a civil cell.  We can create the civil cell without issue but when placing in our corridor it does not behave like we need it to.  I have attached a zip file that contains some documents to explain the steps.  In general the 3D lines that represent the flare of the driveway are placed a good distance away from the original placement of the civil cell.
TIA
Sean
MSV8i 08.11.09.578
Geopak SS3 08.11.09..674
Win 7
CivilCellIssue.zip
  • Sean
    I looked at your document...
    on the second or third page you reference corridor transitions, Civil cells do NOT support multiple template drops, therefore transitions are not supported.
    There may be other issues but this I noticed right away... please see the attached document for what is or is not supported in civil cells.
    Michael Barkasi
    Application Engineer
    Reality Modeling
  • Michael,
    Thanks for the suggestion.  I did see this document you reference after we started creating civil cells and even if we remove the multiple template drops the issue still exists.
    Sean
  • Send me your cell mike.barkasi@Bentley.com
    Michael Barkasi
    Reality Modeling
  • Mike,
    Ricardo Villegas (Bentley) and Kevin McDonald (Bentley) are working with me on this issue.
