I have used the 'Edit Terrain Model' command 'Delete Edge Triangles' to clean up my triangles which changes the shape of my perimeter. If I 'Reactivate Survey Processing Rules' I'll lose my edits and the perimiter will redraw to the original extents. So I want to save the edited perimiter as a linear feature in Survey with a Boundary feature type. The method I'm trying to use is to right mouse click over 'ALL Linear Features' and select 'Add Graphic Linear Feature'. The problem I'm having is when I'm prompted to identify element I get the message "Zero length element not allowed".
I've probably seen something like this, but not necessarily due to a file fence operation. (Unfortunately, we've all seen more than our fair share of corrupt Microstation elements!) I'm guessing the boundary was corrupt before you exported it. Try doing a reference merge of just that boundary line into a clean file. Perhaps you can find - or eliminate - the corruption that way. It has worked for me in the past, for various types of corruption. If that doesn't work, try using a tool that forces the line to be redrawn, such as "change curve direction" or something similar.
Frank Boston
Michigan Dept of Transportation
Survey Support
Not quite sure of your workflow... but watch the minute long video for perhaps an easy more efficient way to get the boundary.
HTH
Michael Barkasi
Application Engineer
Reality Modeling
Also wanted to add if its desirable to have a shape. The horizontal offset boundary line can be copied (becoming a "Line String") then selected and made into a complex shape.
