I have a problem with feature definitions (FD) and templates which affects badly my 3D model.
Components in templates have FD assigned. It happens that when I open the itl file all symbologies for components are lost. Component still have a festure definition assigned but their colors are lost. I need to reasign FD to get color back.
Similar with points. Template points have FD assigned. I double checked dgnlibs with FD and element templates - that seems to be fine. But when I create corridor all linestrings created from template points are drawn on a Default level.
Any idea how to deal with that? I was strugling with that few times and did not find any solution.
Please note that when I use the same feature definition to create civil geometry element and assign elevation to it I get a good result in Default=3D model- element is on a level defined in Element Template that is assigned to FD.
TIA,
Adam
Hi Adam,
As a test, I assigned feature definitions to components in my template. I then closed, opened a different ITL, assigned feature definitions to components and then opened my original ITL and the colors were retained.
I’d be happy to test with your data if you’d like to provide your DGN and ITL.
Sanders
I am having this same problem. Was there any confirmed answer?
There is a bug where compressing levels breaks the link to dgnlibs for that session - is this that issue?
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Was there a solution to this? I am having the same problem. Thanks
