Is it possible to have End Conditions target MicroStation Solids. It seems I have seen this done somehow but not sure what the process is. Do I need to get the Solids into a Civil Model as a name object? Basically I have bridge abutment wing walls that I would like to target. In the past we would create DTMs for the wing walls and target them but now with SS3 I have the full bridge (Superstructure and Substructure) drawn in MicroStation Feature Solids and would like to use them. I this possible what am I missing?
Mike, sorry this reply provides no answers, but I was just curious how you are getting your bridge solids- are they being drawn "by hand" using 3D Microstation or are you using a particular vertical authoring application?
The bridge walkway below was done using MicroStation solid feature modeling. So MicroStation only.
Mike LongstreetVermont Agency of TransportationCivil Engineering Technical SupportVTCAD Help
