Is it possible to have End Conditions target MicroStation Solids. It seems I have seen this done somehow but not sure what the process is. Do I need to get the Solids into a Civil Model as a name object? Basically I have bridge abutment wing walls that I would like to target. In the past we would create DTMs for the wing walls and target them but now with SS3 I have the full bridge (Superstructure and Substructure) drawn in MicroStation Feature Solids and would like to use them. I this possible what am I missing?
Mike,
Try to create a terrain model form the mesh elements you created. You should be able to target it that way.
Marc
Assign Feature Definition and a name to your Mesh. And then you can just select it from graphics in your Target Aliasing window.
