Microstation V8i - v08.11.09.608
GEOPAK Suite - v08.11.09.722
We are slowly transitioning to using the Civil Survey tools. However, we still have projects that need to use the traditional GEOPAK Survey tools. While trying to process a DTM using the build DTM from survey data tool it crashes halfway through processing. I get the "System fault: bad memory access" error.
Operating System: Windows 7 Professional 64-bit - 16.0 GB (RAM) - Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz - NVIDIA Quadro 4000
when that happens, make sure that you go to your windows task manager and end any geopak.exe processes that are still running. it should not crash. make sure when you build the dtm that you select the correct dataset and click on the option to create a .dat file
Still not working. I have deleted the .rsc files. Checked and made sure that there are no extraneous processes running. I have tried processing one dataset at a time instead of multiple, and create .dat file is checked in every case. I've also tested this on multiple projects with various datasets.
open your survey project preferences and go to the linking code tab, are the linking codes blank? any of them?
None of them are blank.
can you post your dgn, smd, cel, gpk, and your survey ascii?
Answer Verified By: Rayleen Lee
