Microstation V8i - v08.11.09.608
GEOPAK Suite - v08.11.09.722
We are slowly transitioning to using the Civil Survey tools. However, we still have projects that need to use the traditional GEOPAK Survey tools. While trying to process a DTM using the build DTM from survey data tool it crashes halfway through processing. I get the "System fault: bad memory access" error.
Operating System: Windows 7 Professional 64-bit - 16.0 GB (RAM) - Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz - NVIDIA Quadro 4000
open your survey project preferences and go to the linking code tab, are the linking codes blank? any of them?
None of them are blank.
can you post your dgn, smd, cel, gpk, and your survey ascii?
Answer Verified By: Rayleen Lee
