I am attempting to show existing storm drain pipes on the sections.
I created features and element templates for the pipes. The element template uses a cell for the pipe.
Everything appears correct in the cross section view in the modeler. The pipes are viewed properly.
When I create cross sections I get bad results.
Proposed roadway model does not appear, geopak cells are not grouped properly, pipes do not show as in modeler.
The proposed cross section DGN (mHC-MD197_MD197.dgn) is a mess.
I started the cross sections using a 2d seed model. I referenced the 2d corridor model with no nesting then the 3d corridor model with nesting depth=99.
The cross section file is mHC-MD197_MD197.dgn
The main corridor DGN is MD197.dgn
I uploaded/posted the files to the Road and Site Design as
Geopak_Support_2014_08_27.zip
Thank you for your assistance.
Philip Mashuda
May I ask if you tried the SUE tools. I might suggest trying these as well.
No I have not tried the SUE tools.
I am new to using SS3. I would like to avoid the additional learning curve with the additional software.
Do you happen to know if there is an additional charge for activating the license?
I do not believe there is an additional charge for SUE.
Which of the files has the element templates for the utilities?
Beebe,
mTO-S000_MD197_JMT.dgn is a file containing storm drain pipes and sanitary pipes.
Sanitary pipes are on level UTIL-SSWR-UNDR
And storm drain pipes are on level STRM-PIPE
Element templates are define for the various sizes of pipes in the file.
Phil
