I am attempting to show existing storm drain pipes on the sections.
I created features and element templates for the pipes. The element template uses a cell for the pipe.
Everything appears correct in the cross section view in the modeler. The pipes are viewed properly.
When I create cross sections I get bad results.
Proposed roadway model does not appear, geopak cells are not grouped properly, pipes do not show as in modeler.
The proposed cross section DGN (mHC-MD197_MD197.dgn) is a mess.
I started the cross sections using a 2d seed model. I referenced the 2d corridor model with no nesting then the 3d corridor model with nesting depth=99.
The cross section file is mHC-MD197_MD197.dgn
The main corridor DGN is MD197.dgn
I uploaded/posted the files to the Road and Site Design as
Geopak_Support_2014_08_27.zip
Thank you for your assistance.
Philip Mashuda
Nico,
I hope that your suggestion still works because I am having no luck plotting utilities using features.
Phil
I was informed that there is a charge for SUE tools so I guess that option is out.
Philip: Beebe and others can help you with the original workflow you started, although it seems that you have arrived at what I think is the expected result. The utility feature lines will show as a point in the cross-sections which can then be labeled with a text notation. If you want more than simply an X at the location on the cross-sections then you can define a cell in the element template, which can produce (for example) a circle. But, you probably already figured this out.
The SUE tools will produce 3D models of the utility lines and thus the cross-sections will show a LOT more detail since you will se a slice of the actual solids. The learning curve is not steep. You could be producing models of utility lines in an hour or less and I am happy to help you with this if you are interested. If you need customized utility node structures then there is some additional setup required, but sounds like your main interest is the buried linear utilities.
However, there is an additional license fee for SUE. I'm happy to discuss these costs along with your account manager if you wish. I would suggest that a conversation about the cost versus efficiency gains in the workflow you are attempting would be worthwhile. Keep in mind that you do not need to maintain a 1:1 ratio of SUE licnese compared to the number of geopak licenses you own. A small percentage of SUE license shared among your staff staff of many geopak users is adequate in many organizations.
Robert GarrettSenior Product EngineerBentley Systems Inc.
The bad results in cross section is occurring due to the design file having a shift in the global origin. A defect has been filed on this that will be either fixed in the upcoming SS3 MR or SS4.
The workaround is to create a dgn file from your 3D seed. The seed has the shift in GO for X,Y,Z. Then create a 2D design model in the dgn for your geometry. Then when you attach a 3d file or create 3d geometry OpenRoads will create the 3d model with the global origin shifted in the x,y,z to match your design file shift.
