Dear All.
where we should use non tangential alignment. what is the use.
Sreenivasulu Bachu
Kindly go through the link below, that gives details about the Non-tangential alignment.
communities.bentley.com/.../2262.aspx
Hope this helps.
Amitha thanksfor your reply i will go through that.
sreenivas
Amitha i seen that link but my question is i seen some alignment in that i found only curves no tangent . May be i have to post it separately as different post.
Non-tangential alignments are alignments that can be created with a 'kink' in them - for example, two straights meeting at a point. It is nothing to do with an alignment that I made up of curves only. That is a standard alignment that just happens to have no straights in it.
Mr. Mark Marnell,
Please write about alignment only with curves, i seen horizontal alignment and vertical alignment with only curves in hard copy , if i want to make shop drawings with same hip and tangents MXROAD not allowing to make alignment it needs some straights in between curves. May be they made it by other software. Please write.
Sreenivas Bachu
