OpenRoads (Geopak) End-Area Volumes problem
I am having a problem with my corridor design surface not showing up in the General area of the End-Area Volumes tool.  The exisitng surface is listed but the corridor design surface is not however, the components of the corridor do show in the list.
I did scroll down in the list to see if design surface was there.
Anyone have any quick advice?  The dgn file is over 10 mb so if someone needs the dataset I can send.
TIA
Geopak ver. 08.11.09.722
MSV8i ver. 08.11.09.608
Parents Reply
  • Just to give an update.  Based upon discussions with Kevin McDonald (Bentley) the components of my corridor became orphaned after I clipped my corridor.  Any component mesh has the potential to be orphaned.  There is a workaround but you will have to contact Bentley support.  The workaround fixed my orphaned components issue.  I have not had this issue on other corridors just this particular one.  Kevin confirmed that this issue is resolved in the next release.
    Thanks to Kevin for the assistance.
    Answer Verified By: Nico Roman
