I applied to a terrain model (feature definition sets volume option as:substratum) surface templaters limited with boundries. Feature Definition for templates's components have volume option set to substratum as well.
However, when calculating eatrhworks from cross-sections, surface templates are listed as design surface type in the General Leaf.
Hence I have to change component classification for these components for unsuitable.
Unfortunately cut volume is not reduced by unsuitable material removal. Neither in report nor on cross-section cut area shapes. In fill these removal volumes are not added to fill volume.
Any ideas? I am looking for a way to obsolate unsuitable material by feature option from Inroads SS2 release to include existing pavement, weak ground and topsoil removals. Using unsuitable material by station is not an option.
Thanks.
The surface type is what is stored on the terrain and called up on the General Leaf. The different options for Surface Type are Existing, Design, Substratum, Ignore, or Subgrade. From the Help:
Existing type is for the original ground surface as surveyed. This is the default for most newly created surfaces.
Design type is for the surface that you are designing that you will be comparing against the existing surface for volumes. This is the default type for surfaces created by Roadway Designer.
Substratum type is the type for existing subsurface layers, such as rock, sand, clay etc. If you select Substrata, the Cross Section symbology from the Advance tab of Surface Properties will be used to control the symbology of substrata shapes produced by End-Area Volumes.
Ignore means that this surface is not to be used in computing volumes.
Subgrade type is the type you use to compute end area volumes that have a subgrade surface.
Then under the Classifications Tab, this is dealing with the material type for the components not the surface type.
What is the ultimate output you are looking for? Do you need the volumes reported based on each substrata terrain to the existing terrain to give you a cut/fill volume to each of these terrains as if they are 'layers'?
I want ot make sure to know the surface type and the clasification type are referring to completely different things. It would also be good if you could include a DGN with the terrains and sections so we can go through the volumes and check out the report to see how it will report everything versus what you are looking to get as an output.
Chris,
Please see the attached video. Two questions:1) Why Soil_Exchange Surface Template is Design type instead Substrata (video time 1:00)? As you can see at the beginning of the video, Feature Definition assigned to the component has Substrata volume option set.2) Why Unsuitable Material by Station overlaps with my Soil_Exachange at some stations (video time 1:30 and forward)?Thanks, Krzysztof
And going further, question number three:3) shouldn't the red area be also included in cut area?
Thanks, Krzysztof
1. I noticed you have a Soil_Exchange and a Soil_Exchange Surface Template listed as terrains. Is the Soil_Exchange Surface Template a terrain generated from the corridor terrain mesh and not necessarily the Component? I am not sure where each of these is coming from.
2. When you do an unsuitable material by station, it should take the extents/limit of the design surface as the offset limits for the unsuitable material component. The unsuitable material should run all the way across the design surface.
3. Are you referring to the closed shape for the unsuitable material? If so, yes, it should be uncluded in the cut volume. Does the normal cut line not represent this when you annotate the end area volumes?
