On a roadway I am designing using Corridor Modeling & Roadway Designer I am unable to generate the limits of construction. My proposed templates are created properly (I believe) with one of the end conditions as "End Condition as Infinite". They look correct in both Roadway Designer and when I generate them onto the cross sections. In Roadway Designer I dropped the templates at 10 ft intervals, my cross sections are at 50 ft intervals. Also, the proposed cut/fill slope lines intersect the existing surface (or so it appears).
In the Limits of Construction dialogue, I select the existing surface level for the "Existing Ground Line" and all of the proposed element levels for the "Proposed Finish Grade". Tolerance is set to 0.10. When I hit "apply", there are only a hand full of sections that process correctly (for a 5 mile section of roadway). For the other sections that don't process correctly, I get one of the following messages:
'Unable to find more than one point of intersection between Proposed Finish Grade & Existing Ground. Check your tolerance"
or
"XS-DANGLT Proposed elements do not tie to the existing ground on the left-hand side of the the cross-section at station:"
Is there something wrong with my workflow? What do I need to do to be able to generate the limits of construction lines?
TIA
what software/version are you using?
Microstation SS2 V08.11.07.443
Geopak V8i SS2 V08.11.07.566
ok. ultimately, when you have your xs done, you can just run the ancillary data tool from geopak and place the construction limtis that way
Thanks for your response Nico.
I am not familiar with the ancillary tool but just tried to use it. Won't this tool put points on the cross sections at the limits of construction?
I am looking to generate a line (slope stake line) from the cross sections that can be generated and shown in plan view on my removal & construction sheets.
Regards.
ok. in that case, we have a construction limit tool under the xs tools in geopak. there, you can have it draw the actual limits from the xs to a plan file you specify.
