Dear All ,
I am trying to delete some points in triangulation but not working is there any other way.
Sreenivasulu Bachu
It would help us answer your question if you also told what product you are running, also, what version, and what command you are using to delete the points.
It is posible by going in Surface--> edit surface--> delete triangles . Is this what you are looking for ?
If it is an MX triangulation created from a string model you can use masking to remove points or strings from the triangulation analysis process and create the desired triangulation model.
MXSS2 , MODIFY/EDIT/DELIT ONE POINT
I CONT FIND SURFACE /EDIT SURFACE TOOL
