It's possible that you just minimized it. Clicked on the Hide Details icon just to the right of the Show Details icon. Then click back on the Show Details icon. I believe this will resolve your issue.
I tried it. But the issue continues.
Any other suggestion?
I have uploaded a video.
Thanks.
You can also try deleting the Registry Key "DialogPos" in the Registry. It is located in HKEY_CURRENT_USER\Software\Bentley\InRoadsGroup\Applications\Version 8.11.9\DialogPos. This will reset all dialogs to their default location.
Thank you very much for your help.
I tried both solutions but without effect.
I have found that if I change user popup appears again but if I return the user "examples" disappears again.
Any suggestions? I need to continue working with the user "Examples".
The simplest way to correct this is to delete examples.ucf . Then go into your Windows Control Panel>Programs and Features and run a "repair" on InRoads.
Thank you very much Jacquelyn.
I also tried this but it has not been the solution.
A new examples.ucf has been created but has not resolve the issue.
I think the problem is in "Bentley-Civil-Metric". If I change this file the problem seems to be solved.
In that case, I would try deleting the Bentley-Civil-Metric.pcf located in C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\Projects\Examples.
You can replace it with the file I have attached.
